- Saginaw MI
I just installed a new digital brain on my Rok. Good spark with the plugs on the motor as you have but wouldn't start, just cough. I did have to switch plug wires front to back for some reason with the new brain, something Msd has changed internally in their build I'm sure but whatever, prob solved n it rips once again.
You need to shoot your timing with a lite period. All the dip switch settings work with each other to get the desired curve based off that starting point. You have to know where your starting from to get it rite. That said, my static timing is higher than 31 degrees and the motor actually stalls the starter most every time I start it due to the high advance. But it still starts good and runs as it should. Too much static timing won't cause your symptoms IMO. Spec on the gap between the triggers and magnet on the wheel is .050-.090" also. I have set them up at the .050" n had problems. .075-.090 is the sweet spot I have found. Good luck, elect probs are a pain!
