speedysprocket
Alex
- Chesapeake, VA
And switch your plug wires to see if it'll fire, just for the hell of it...
Please make sure you have compression, then squirting in gas should make it fire unless the timing is way off. It's sparking well in the vid but is it at the right time.
They're not so much leaky as they just seem to get wet around the plates on the back of the carbs. Probably the crappy SBT seals I have in there. I should buy a rebuild kit directly from Mikuni.I think we're worried that you ride with leaky carbs. What exactly is leaking?
Only have one set :-/And switch your plug wires to see if it'll fire, just for the hell of it...
From what I can recall, the airgap was 0.094" right at the top of the limit. How do you adjust for this, mini shims of some kind?Just to make sure it's checked off your list, what did you set the air gap at between the pickups and the magnet on the back of the flywheel?
Oh, got it. My coils are some 6 inches away from the brain making it already stretched with the one short one long wires I have. Only the long wire right now will reach the front hole.No, plug wires from front plug to rear plug. Leave coil side of the wires on.
Compression - Check. It's there at ~175psi per hole. It looks like it is a timing thing. I'm pretty sure I was at 31 static, with -2 Max Timing putting me at 29, but I'll take a closer look at it next weekend. The toughest part about working on this thing is that I can only do it on the weekends, when I want to ride!
Needle & Seat: stock (55 psi)
good god thats high.
Your sure your dip switches are set correctly?
Your brain isn't set to test mode is it?
