- Michigan
Let me start off with saying - not a mechanic by any means . 1990 - 650 square nose. Push start button - no click and no start . I have replaced S/S switch , starter relay , positive cables from battery to starter relay and from starter relay to starter . I also put in a new ground cable and had starter rebuilt . I have tested new S/S switch and starter relay in my other Superjet and they work fine. I also did the test on starter relay where you connect two small wires and starter does engage. I have disconnected stop switch wires ( black and white ) and still no go . I have checked continuity in wires and all seem fine . I have tried 3 different charged batteries while also using a jumper just in case . I am at wits end . Any more ideas ? Would a bad stator or coil cause no click and no start ?
