Just the time you will have to babysit the 5200 to keep it from running away from the tube.That will be a painHow do you prep heatshrink to insure epoxy bond with it? or just 5200 the chit outta it ?
they make 5200 in black? how am I just now hearing about it?
I though that was black magic RTV?Uhh yeah... Just takes like a freaking week to cure. Seems that if you use it on a pump shoe and it doesn't have adequate time to dry it shows up in the wear ring........ just a theory
Have not decided, thought about just foaming the section where the waterlines are, the stringer seperates the left side and right side. Or just put some insulation board down in there. May go ahead and foam it all. Not decided.are you foaming the tray?
