- Tuscaloosa, AL
CRAP, been so long, cannot remember which lbs foam to order.
OOPS TOO late I see.Not sure if you know this but you can buy Carbon fiber tube fairly cheap.
OK, Who has added a Bow Eye Fitting in the rear of the tray (Stern Eye).
http://www.thrustinnovations.com/thrust-products-c-6/thrust-innovations-ti-billet-bow-eye-p-610.html
Thought about adding this to the underside of the tray, Mount the plate and screws and then turf over with the 1" Underpadding........ ?
Not to be used with ratchet straps. I use hitch hauler for tripsThey make another one but don't see it on their site, I think it's new, mounts to one of the reduction nozzel ear bolts, not sure if you've seen those
Edit: here it is, I see you saw these though
http://www.x-h2o.com/index.php?threads/thrust-innovations-tow-tie-eye.174567/#post-1891618
Ive done it several times with less expensive d rings. Works fine.OK, Who has added a Bow Eye Fitting in the rear of the tray (Stern Eye).
Try Bosen products.They are on the web and great price too.Through the hull with a big fat washer.Cut the excess offOK, Who has added a Bow Eye Fitting in the rear of the tray (Stern Eye).
Crap l remember that day! About wore us out.I like the oem method here too. Drill a hole and put a tow bushing through it. Tow point should be in the center anyway. It will pull you sideways if not. Took me and Don forever to get in at Hugo when I ran out of gas. Plus!, it's free to drill a hole in your hull and you probably already have a bushing.
Sent from my SM-G900V using Tapatalk
