- Kansas City MO
I'm planning on sending the flywheel away to #.2 to lighten....he said that you can lighten this flywheel by about .8 pounds of the rotating mass... that will work VERY well for me...have a set of Blackjack 46 on the way soon...so here's my rebuild list..
- Refoam
- repair hull (fix some of the wear on bottom plus thru hull bearings)
- Install trim system
- custom paint (top black bottom white)
- returf
- new carbs
- replace piston rings
- lighten flywheel
- port cyls just an additional mm on each side plus polish ex manifold
Daytona??? Maybe. I have a long way to go.
- Refoam
- returf
- new carbs
- lighten flywheel
