- Long Island
There is less volume in a mag pump b/c the hub is a larger diameter and the extra vanes take up more volume. In turn it takes less water to "prime" the pump. White water contains alot less water per volume b/c of the air bubbles. In turn the mags typically out preform standard pumps in white water because the mags can prime, grab water and shoot you on your way a little bit sooner
Then my wavejammer is going to go to the moon!If that theory about less volume is correct then that fx-1 122 mm pump should outperform everything!
The key to whitewash is keeping your pumped primed. A good way to do this is restricting how much volume can leave the pump.
If whitewash is something that plagues you, look into reducing the diameter of your reduction nozzle.
