JT_Freeride
John Tetenes @Jtetenes
- Long Island
They are completly different the new one is a softer rubber like the oem is and the metal ring inside isnt as thick as the R&D, honestly I would never recommend the R&D one unless you have to push your pump back like 3mm for some odd reason.nice write up.
can you explain the difference between the R&D seal and the one JM & Thrust sell? I am in the same boat as you were, i bought the R&D seal and it ended up being to thick as you described. I made a jig and milled it down to fit my setup. I assumed the JM & Thrust ones would have been the same as the R&D, but it sounds like they are different.
