JT_Freeride
John Tetenes @Jtetenes
- Long Island
Can someone explain to me what exactly the benefits to a mag pump over stock are?
There is no magic pump to overcome and compress nothing but a bunch of foam and air bubbles. What goes in the pump comes back out.
The mag pump was designed in the hayday of racing . I would say with the introduction of the larger hub they were looking for more preasure and efficiency at high rpm's. How that rolls over into freeride/freestyle ...? I have been under the impression that more volume = more thrust. I know its not as exacting as that but it is a fact. Lets hear it from the fluid dynamic majors.Can someone explain to me what exactly the benefits to a mag pump over stock are?
You know, decreasing that volume obviously increases the velocity, right? But counter intuitive to that is that as velocity increases, pressure actually decreases...I gave my .02 earlier in this thread
I dont get IFluid dynamics was one of my favorite classes in schoo and I wish I knew enough to apply math to this problem, but best I can say is this:
Water is not compressible. Air can be compressed.
Two 144 pumps take in say 50% water, 50% air.
Both pumps have an intake area of approximately 162 square cm (driveshaft area neglected).
Mag pump hub occupies 41 sq cm. So not taking into account the cross sectional area occupied by the vanes, there's a 25% reduction in cross section.
Now what's the diameter of a stock pump hub, like 60mm? I don't have one in at the office to measure...
Assuming that, cross sectional area is 28 sq cm. That results in a cross sectional area reduction of only 17%.
So, while it's still not ideal, the mag should compress 8% more air than the stock, resulting in 8% more water coming out as thrust.
Does that make sense? @DAG ...?
Correct so all things being equal meaning thrust speed out of the nozzle , more volume creates better thrustYou know, decreasing that volume obviously increases the velocity, right? But counter intuitive to that is that as velocity increases, pressure actually decreases...
My puny brain doesnt get ItFluid dynamics was one of my favorite classes in school, and I wish I knew enough to apply math to this problem, but best I can say is this:
No, I would say that is not correct. Thrust is the end result, but there's more than volume that goes into that.I dont get I
And if your running any taller of pitch than 13/17 for freestyle, you need a bigger pump.
Sound advice. A number for pumping up.
Sent from my iSpud using Tapatalk
My big hub 7/12 works great but could use a little more snap off the bottom. I'll be in wavedaze I'll look for you and maybe we can get a side by side comparison.report back from a ride with an oem 760 prop. Yes it works but not so good. The big hub 6/12 I'm throwing in now the hub is significantly bigger. So great results will be felt first test will be in Virginia on this pump setup.
Air blair cell
Thanks for the added principles. It's been 7 years since I had a lesson in fluids, unfortunately. Can you talk to the vane number and shape...?The tip speed of the impeller determines the max pressure. Bernoulli the reason we can and should use the largest hub possible. It is common to see 70MPH out of the nozzle. Now, understand that the tip speed of a 144 impeller spinning 7000rpm is 118MPH while the 75mm hub is only going 62MPH, a 50mm hub is only moving 42MPH. The slower moving water is at a higher pressure than the faster water that is further away from the hub. This water and whatever air present has to circulate into the faster moving fluid where the speed is averaged. The larger hub simply reduces the amount of dead water present. Entrained air will flow backward at the hub and short circuit the impeller until it clears. This is why large hub impellers work better.
