Yes Its obvious that a stuffed pump has less volume so its quicker to fill with water. Not sure where your going with that but it looks like you agree that greater volume equals greater movement of mass. Which in turn woulld mean stuffing or bighibbing a ump is counteractive tolow end needing freestylers . No?Big hubs reduce internal volume so the inside of the pump can fill and prime faster. This theory is for any pump diameter. Bigger pumps give better hole shot or bottom end power and will reach the same speeds but doing it with less pressure and more volume. To a certain amount. Eventually to get higher speeds you will need more hp to power the pump to higher pressure, or go down in pump size and setup the smaller pump to create a higher spped pressure at the loss of some bottom end. Pumps are very tuneable.
Your kind of getting all over the place . What does prop pitch have to do with pump volume? And doesnt it litterally take a split second to prime a pump no mater cone size or stuffer or whatever? So im not understanding your theory of it being your "timing" of a pump. Its really not much volume difference we are talking about here ... maybe 1/100th or less of a volume differance?It's always going to be the magic sweet spot ratio of pressure and volume by a given prop pitch. Tuning by the tail cone volumes and using big hubs in combination with reduction nozzle diameters is how you get your pump to respond well to rpms and your engine power delivery.
Pump tuning is a magic dark art.Probably going to OT my own thread but I'm curious if any of the old Yamaha/Kawasaki development engineers are on the jap forms laying out the tech Q&A details. It sure would be nice to understand how/why things work better than the jibber jabber we post all over the place. We assume so much stuff but I guess that's all we have... Can we get a fellow to join the forum for Christmas? That's my only wish![]()
I measured my jet stream at 70mph. This is not a very effecient way to make thrust at low hull speeds. More low speed thrust can be made with the same power by trading some of that pressure for volume. Adding stator vanes reduces backfilling behind the impeller blades. This becomes most important when there is a lot of air in the water. Large hubs fill a dead area that otherwise holds circulating water and air. The compressed air within the pump expands and blows water out the front whenever the inlet stream is interrupted. The pump cannot reprime untill intermal pressure drops.
This test was done by measuring static thrust on a Superjet strapped to my test trailer and sunk as deep as possible. I simply measured the nozzle area and thrust, then used a dynamic pressure calculator to get the speed. For full speed testing I plan to make a pitot ring behind the nozzle but havent had time.How? 70 mph? Couch? I'm curious now
Prop pitch is like the gearing. Not much volume difference in cylinder heads either but a few cc's makes a difference. Now try compressing water. If internal volumes makes no difference why would we have different tailcones to help change internal pump volume. Why does a slight prop repitch make a difference? What part of pump timing vs engine rpm do you not understand?
