Doug, That is very intresting! Thank you!
It's giving me something to think about!!!!
Not a problem! :biggrin: What almost appears to me is that an inbalance would cause fatigue (bending back and forth) stress right at the hub causing a failure. I bet someone could simulate it with a flywheel coupled directly to an electric motor. If the flywheel was given an inbalance on purpose and just let go to spin until failure, I'd be curious to see what would happen.
Doug
In a perfect world, what you are saying is true, but think about what happens in a watercraft motor........
constant throttle change, which relates to constant rpm change. This is coupled to drastic acceleration & de-celeration in high compression, Modified motors.........
Now you also have pump loading & un-loading..............
Are you starting to see the severe service these flywheels are put thru?
So when modifing them, the key is to see how close you can get to the ragged edge, without crossing the line???
I do rebalance the flywheels after they are lightened. But that is only margionaly helpful when the mass strenth is removed. That is because of the differant harmonic frequencies are varied RPM levels.
I would be very intrested if you can do your test under varied conditions as I just stated. Then I would have a better Idea of exactly where the line is?
There use to be a product called the "Fluid Balancer". It was a PTO flywheel for the Rotax motors. Those flywheels had captured ball bearings in a groove running around the outer edges. When the motor was running, the balls would find the balance point at all rpm levels. Thus balancing the flywheel & making the motors last a good long time. It would be cool if it was possible in our motors?
ski ya, Paul
Douglee, That's really cool software!:hail: Can you model in the outside diameter and face taper cut then re-analyze?
I'm glad this doesn't happen to skis...:skull2: http://images.google.com/imgres?img...channel=s&rls=org.mozilla:en-US:official&sa=G
I'm unsure of your explanation? I understand face taper cut, I'm unusure about modeling the outside diameter?
Doug
Lightened stocker here too (Paul) and it made a very nice noticeable difference.
It's roughly a 1/2 pond removed from the outer face/side.
I will never go back but I would go charging alum if they were like 200 new.
Im not at all qualified to chime in on this, but here goes , what would happen if you drill 2 more holes in the high stress areas ,would this even out the loads since the loads are in the non-hole areas ?? mabe try to run it through the program again with 2 more holes ! !I was curious if the failure of the flywheel was due to machining on the face (front side) or the actual flywheel having an inbalance. I drew up a rough sketch of the flywheel in Solidworks and threw it into the finite element analysis program. I kept the hub as the restrained piece and loaded the flywheel (normal to the outer diameter). This would represent an inbalance to the flywheel while spinning.
Check out the results. The scale on the side goes from red to blue. Red signifies areas of high stress, while blue signifies areas of low stress. Look at where the levels are the highest? The area is right around the hub. That is identical to where the previous picture shows the failure.
Doug
hey matt..whatever happeneed with you and Jetinetics?
I cracked the hub of my charging wheel, sent them an email and they said to send it in!
I rmember back awhile ago you were having tons of trouble just getting them on the phone....did you give up?
I was going to have my flywheels lightened over the winter and just pulled the SJ, so I went to the blaster and found this. I take it this is lightened, and about all that should be removed.
If lightening the stock flywheel makes that big of a difference, I wonder what the Riva flywheel will do? Before it cracks that is, and throws out my timing.
1.5 lb should make a big difference, however I am going to keep my stock lightened flywheel for backup.
