Custom/Hybrid Okie XFS 771 Build
Yami-Rider
TigerCraft FV-PRO
Texoma
Hey everyone! Figured i would post up this build I'm working on. The ski belongs to one of my local riding buddies(Alan). The ski is a 2012 XFS.
Gotta love the black.
from the back
This is a exhaust extension that i was told is a must have part when running a trim setup. I made it out of 2" PVC.
Before
After
Added some foam to the hood, not sure if it would float without it?
X-Scream waterbox....Seems very well made and looks a lot better then the old beat up stock waterbox.
Not much in the engine bay yet.
Me and Alan running the cables and wires.
Me taking a nap after we were done.
Yami-Rider
TigerCraft FV-PRO
Texoma
First blood!! The hooker cut me! The 11/17 hooker is razor sharp. I have been around a lot of hookers...I mean impellers and have never seen one so sharp.
144mm Skat-Mag...What a beauty.
More Mag
The hooker installed
Yami-Rider
TigerCraft FV-PRO
Texoma
Nothing to exciting today...
Finished up duct shoe install
Finished putting the pump together and installed it on the ski. Still have to do more hull to pump shimming.
Installed homemade nose foam.
Texan33
Yacht Wakes Hunter
Texas
Whoo Whoo!! Looks good!
Will do. Planning on using loctite on those bolts
I used loctite on some bolts that was expose to water on normal rides. A few months later, I took some bolts off and discovered the loctite has turns into white-ish powder.
munki63
Epoxy is my duct tape
Canada
Sweet build bro... I had a RN771 and the 10/16 was to aggressive... Not sue if a light weight hull will change that
where did you hear about the exhaust extension and why? My buddys XFR doesn't have one
Yami-Rider
TigerCraft FV-PRO
Texoma
I was told by a local rider that has a XFR, when you have trim and turn sharp to the left it can blow water back up the ex. tube and cause the motor to bog.
The motor was ported by blue and built jetmaniac (chris), chris told me that prop will be good for freestyle.
