speedysprocket
Alex
- Chesapeake, VA
Is that 1/8 or 1/16 NPT? How thick is the pipe in that spot?
Thanks for the picture, Chad!
npt...not pinning throttle? lol youse funny.. Told you I had the npt tap and right size jet and the best location point,just gotta get the spray bar from alex,lets do it for tomorrows river ride.Wtf is npt
I think more of an optical illusion. 9-deg 1st diff, 15-deg 2nd diff, 70% diff/dwell position, 20-deg baf, 7000rpm hp peak
Works very well, I need bigger pump as my DASA1200 on pumpgas at 5000ft spins my 14/21 146mm SB Skat.
A pic of the pieces tacked together, will need less cuts/bends on final version.
Chad why did you decide to mount yours in the thin area? you need just the edge inside to spray across the full I/d ?
