So I have decided to update the midshaft housing to the newer round nose midshaft housing and drill and tap new inserts for the different bolt pattern. I have a GP760 midshaft and housing in great condition so I am going to knock out two birds with one stone, update the housing and move the engine back one inch. The gp760 midshaft is not only the proper thread for AM couplers, its also one inch shorter.
I will be adding a couple of inches to the rear of motor mounts to accommodate this. First I wanted to flatten the chine area to make it easier to build up the new glass for the motor mounts. I started by cutting increasing width strips from half inch up to 3.5 inches. This should create a reverse pyramid and help to fill in the chine.
With the glass to fill in the chine it will be much easier to build up material to the same plane as the motor mounts. Once built up I will sand down flush with the mounts and epoxy in inserts 1" back from stock. Additionally I will be filling in the voids in the mounts since I will need to epoxy in a insert there as well.
Once this and the motor mount extension are cured and sanded I will then reinforce the entire engine bay encapsulating the motor mounts and glass work.
I should be able to wet this out tomorrow, its a pretty light day at work.
