I have a question for any of you composite guys out there about the nose reinforcement.
I am filling all of the low spots of the outside of the squares nose with 4lb pour foam so I can reshape it a little bit and improve its aesthetic. Additionally I am extending the pole bracket area a few inches forward, so I will be pouring foam on the inside of the pole bracket area as well. This creates a backer for when I start cutting out that raised section on the squares nose, just in front of the bracket area.
My question is will the foam and the fiberglass, once its shaped and covered, be enough strength to skip reinforcement on the upper part of the nose? Should I reinforce before I pour the foam and cut out the area I am planning?
Additionally I am re angling the rub rail for a fake rocker look. I am going to cut it like a horseshoe starting at the front hood seal and kick it up at the nose about 2" without changing the geometry of the wetted surface of the hull. I will then fiberglass it back to the hull where I want and then shape the nose to match the new lines. Does fiberglass (or smc/metton) do ok under tension or will I need to slice the rub rail a bit to allow it to follow the arc?
Thanks!
Thanks!
