Inner Glasswork Part 4 (The part in which our hero finds a semblance of redemption and moves onto other jobs)
Having received some excellent advice over the last week both here and on the other pwc forum (the blue one not the green one) I started by raising the hull up and allowing it to stand nose up. Fortunately I installed a overhead hoist to raise the transmission up when I was installing a new clutch on my old N18 Mini Cooper S so it was just a matter of adding a rope and cranking away. Of course, I didn't do it that way because I am not that smart when it comes to simple stuff. Instead, I did some seriously sketchy workout maneuvers to raise the hull up with one hand while clipping the stern strap to the lifting hook... You can't fix stupid (I have tried) but it worked and I wasn't squished.
I started by mixing 4OZ of resin and cabosil into some deliciously smooth peanut butter and stuffed that up in my nose. I then mixed up another 8OZ of resin and smeared that all over the repair areas and let it start to kick. While that was gelling, I started cooking some italian sausage in a red sauce.
Recipe (NOTE: ADD SEASONING TO TASTE)
5 links Italian Sausage
1 Head Garlic, peeled and chopped ( I do bigger chunks but you do you...)
1/2 Large Yellow onion, halved again and cut into thin rings
4OZ Olive Oil
2 Large cans San Marzano Tomatoes
6 OZ Red Wine
2 OZ Balsamic Vinegar
2 TBSP Granulated Chicken Bouillon
1 TBSP Capers with splash of Sauce
2 TBSP Sun Dried Tomatoes with sauce
As much Basil as you can find
Tomato Paste
Brown the sausage in a large dutch oven over medium heat.
Once browned on 2 sides add olive oil and allow to heat for a few minutes then add onions and garlic stirring occasionally.
Remove Sausage from dutch oven and slice into thin sections. Add back to onions and garlic on stove stirring frequently.
Once sausage has had time for the fat to render into pan, add remaining ingredients and simmer for at least 30 minutes.
Return to garage to continue fiberglass work.
Time Spent:
4 Hours including waiting for the epoxy to gel
Tools Used:
Rockwell Oscillating Multi Tool
5" Orbital Sander
Shop Vac
Mixing Cups
Mixing Stick
Materials Used:
8 OZ Denatured Alcohol
4 Blue Shop Towels
16 OZ Resin/Hardener
16" 1208 Cloth
1 Hazard Fart Paint Brush
Painters Tape
Old Repairs Removed:
Nose Job part 2
Kawasaki Bonding Adhesive Removed:
2lbs
Muscles Strained:
2
PPE Used:
Half Respirator
Tyvek Suit
3M Worktunes Headhones
Black Spider Gloves from Blowes
Items of Clothing Ruined:
Tyvek Suit (Walked past my tubing notcher and caught the back of it on a 1-5/8" Hole Saw...)
Chemical Burns from Epoxy:
1
Percentage of Garage Floor Epoxy Coated
18%
Percentage complete:
65% (I will finish up the bond line reinforcement tomorrow. )
Sean
Workshop Before, this is where the magic disasters happen
Find the winch
Strung Up
Lit Up
Cut Up
Stuck Up
Covered Up
Nose Up
