Hooker.......... Everything is better with a hooker!
SM
From what I've heard, a hooker is exactly the same as a skat c75, just branded for Impros but actually still made by skat.
SM
Yup agree, and also not mentioning what brand of prop. A 15/ 19 Solas is not the same as 15/19 Skat. Well this is a Kawi 1100 build thread so answers should be specifically to that...not Yami 1100 or 1200 here
Given the fact Hooker props use Solas impeller tools and not Skat Trak tools, I believe Hookers are rebranded/ modified Solas propsFrom what I've heard, a hooker is exactly the same as a skat c75, just branded for Impros but actually still made by skat.
I machined the step on the outside of shaft down and tapped shaft further through bearing in housing, only needed a couple of mm, and need to make sure pump shaft doesnt bottom out in midshaftUpdate: I called ADA I do like Rick said have the smallest Kawi couplers they have. Maybe I can tap the midshaft back a little and also try to loosen the motor mount and see if i can get it there? Anyone else have luck doing something else thanks.
This is incorrect info on my thread. You need the same coupler on both sides. You need the one on the left side of the photo x 2 qty. The coupler is referred to as the kawi engine or crank shaft coupler. The coupler kit in the photos from M5 are for yamaha's that want to use smaller diameter/kawi couplers and not specifically for the rad dudes 1100 conversion.These are what you need if going with the Rad Dudes Kit. The shorter 45mm coupler with the hole goes on the motor side, and the 60mm one goes on the cutback shaft which measures 122mm.
View attachment 307026View attachment 307024View attachment 307025
Oops sorry, let me try to remove itThis is incorrect info on my thread. You need the same coupler on both sides. You need the one on the left side of the photo x 2 qty. The coupler is referred to as the kawi engine or crank shaft coupler. The coupler kit in the photos from M5 are for yamaha's that want to use smaller diameter/kawi couplers and not specifically for the rad dudes 1100 conversion.
