ItsRixter
SoCal Wav Jumping shiznit
- Sunny Diego
Definitely need to get all these socal triple blasters together! I just got mine back up and running last weekend and will probably be at elsinore again on sunday. Pretty sure I had a coil go bad and was having trouble figuring out which one...ended up grabbing my buddies complete ebox cheap and swapped the whole thing and shes back in action.
I am running both the temp sensor jumped and the R&D timing plate with no issues as scottiemac suggested but I am still running stock compression so I am sure that helps...looking to mill the head or get an ADA sooner than later though. Also is yours super loud? I like how it sounds but after riding for awhile it gets old and Im sure others dont appreciate it after a while either, would like to quiet it down a little bit without losing power (putting too much water back in the stinger).
I am running a solas 15-22 big hub that impros reccomended but we are going to try a 15-20 or 15-21 like scottiemac suggested on my buddies that will be built soon. Have not been able to check RPMs or MPH yet.
Ski overall runs pretty good and plugs look perfect BUT I do have a low end bog / hesitation I think is due to the accelerator pumps...are you still running yours?
My B1100 does sound a bit louder than my 96 Blaster w Riva Red pipe, but its not insanely loud. I would say its a deeper sound. I did notice that when idling around and turning right, the exhaust was outlet was under water and it was nice to have it muffled. To that point you could keep the stock outlet from the donor ski. It will have a rubber flap or get an SXR downward turning elbow like Scottie mentioned. Another cheap alternative is to wear a helmet (lol). It is a bit like wearing headphones.
