Back to my ski and some tech specs:
I put a Tiny Tach on the ski and it was running top end at 7450 rpm, occasionally hitting 7500.
I used the the GPS speedometer iPhone app that SuperJetJim mentioned. I double bagged my iPhone and put in some foam in the outer bag. I got the ski to 58 MPH. I used the app on two different cars and it shows 2 miles per hour less than car speedo.
So 7450 RPMs, 58 MPH. Using hooker 14.5-17.5 prop on Solas Mag pump. Stock Kehin carbs with choke still installed and stock jetting. 3 degree advance from temp switch sensor. Ocean Pro 31cc dome head (91 octane)
Any thoughts or suggestions? Motor does get pretty hot when running at full throttle for long periods. Much cooler running around at idle (2200 rpm).
Should I put on the R&D advance plate or am I asking for trouble? Maybe slightly higher pitch prop?
