ItsRixter
SoCal Wav Jumping shiznit
- Sunny Diego
This conversion thread is one of the best threads i have read on the X or PWC Today and super, super helpful man. If you don't mind I am in the process of doing mine now and i have a couple questions. Did you install a thru hull fitting to add a second cooling line from the Solas stator section and if you did where did you cut and mount it in the pump section? Also I was thinking about using the same Solas 144 stator section, what made you decide to use that and what did you notice from it as far as performance goes? Also did you remove all the foam in the back. I sure appreciate the help I think i have read your thread twice now awesome thanks, Jason.
Thanks for the compliments. Glad to hear it's helping you out.
Well, the second cooling line can be done a few ways. The easiest is just to use the stock bilge line (yellow arrow) and then install an electric bilge pump. Otherwise, you drill a new line just above it for dual cooling (blue arrow). The other hull pass through marked with red arrow is for the tilt nozzle cable.
Now regarding the pump selection, I was kind of a victim of up selling. LOL. I was told all this power can blow out the stock stator veins. Looking back, I don't think this is a real concern. However, this pump hooks up nice in chop, has great bottom end and doesn't cut off the top end (at least with my prop) at all. Regardless, if you do the pump upgrade, get a big hub prop. It will work on both stock and solas pumps (the solas requires a big hub prop). Now here is the ugly side of the solas pump I didn't discover until afterwards. My front bearing blew out like I found on many threads afterwards. I took the pump apart, and brought it to a machine shop that could work on it (some cannot bore it out due to the wall at the end). It's not only in need of a slight bore due to the tight tolerance, but the guy told me it was slightly oval shaped on the inside section where the bearings sit. Therefore, be sure you have the inside of the solas pump measured and trued if necessary. It was about $50 to bore / true the solas pump. So its really a budget thing. I was "all in" on my from the ground up build, so I spent the extra $$ upfront on the pump. The 1100 on a stock pump with a big hub prop will be great and you can upgrade to solas later. I was also told to use OEM bearings. Be sure to install them correctly. One side of the bearings have etched numbers / lettering. I believe that side faces towards the rear of the ski.
Yes, I removed the rear foam. You have to, to install the rear exhaust. I posted pics in thread. I glassed in the old exhaust outlet so it's all stealth inside the pump area. Foam- PITA part of the project.
Good luck with your build!
