RICKTER talk
So for anyone in the future with the same problem. Avoid wsm driveshafts, tried 2 of them (brand new) and both were an 1/8' longer then oem. Also the splines weren't cut the same. Ended up getting a oem driveshaft and it fits perfectly.
I had one of the first rickter fs1 and had major chipping problems on the hull. How are the next generation 2013-2014 fs2 hulls holding up. Is the paint as brittle?
Stumbled across these the other day, with the square wire hooks from the stock straps or whom ever it was making those one would have endless options for tank/pipe/battery straps.
I used the same style straps for my limitedslip tank in my edge, worked great
Titanstraps look good. I'm checking that out now. I installed a limited Slip in my Edge as well and struggling with straps a bit. I really need two 3" ish ones and it would dialed.
Actually where did you attach the rear straps? I have two Blowsion hooks mounted to the front engine cover and that's where the 3" would be perfect. I have some but they aren't as strong as I prefer.
I epoxied ufo mounts to the hull and the measured the length of strap I needed and bolted through the strap to the mounts.
Just picked up a new to me fs2 evo and I'm kinda worried about the factory rickter scupper flap. Is the rickter specific versi plug better than the thrust rickter ball scupper?
