- Minneapolis, Minnesota
I agree.I would just buy full carbon as 85# sounds perfect but that $10000 price tag is hard to swallow. Lol
Just the competition hulls in some cases. But I also haven’t heard of any competition hull not breaking.Seriously though has anyone ever heard of a Rickter that broke?
Chong son had an old 2010 fr2 that he sold the Brandon lawlor. I ended up with it but it had broken several times across the bottom and had been repaired several times. I never had to touch it.Seriously though has anyone ever heard of a Rickter that broke?
Yepis a sheet of turf enough to cover a rickter xfs tray
Thanks harbor!Found this info on lengths of that helps…
A lot of talk about the newer xfs comp hulls falling apart in the rear.
I'm picking this one up here shortly
The 90-95 Square nose cable works.Thanks harbor!
After checking every sbt yamaha cable length it appears I've got some sort of sit down cable(only ones that are ribbed grey) in there approximately
127.75" long (one end is broken off and It piled up so I cant measure exactly) only cables I can find that's close is a 90-93 650 SJ measuring at 123.75". I've read every yamaha cable description and can't find anything even close to 127. Everything on sbt is either 90", 123" or 140" ish. I fitted a pre 08 SJ cable and it's BARELY long enough to mount with full length tubes, I'm leaning towards the 90-93 650 SJ cable that's 2.5" longer. can anyone confirm if these 650 square cables have been used in the fs2 hulls? Thanks again everyone
