- Ahwahnee, CA
Rickter scupper on my edge did not seal at all if ski was off floating in water. Not great for casual riding, but they do work well if you’re constantly riding.
Good idea… and verify ittly. To verify a water issue, swim it to shore next time it won't start and check a plug.
My Edge stock scupper leaked so I ordered a Thrust Ball Scupper. When Installing it I found the glue they used to install the stock scupper valve ran onto the smooth surface should mate to the flap of the scupper causing it to leak. I have a feeling if I would have just removed the excess glue the scupper would have worked better. Regardless the Thrust Ball Scupper is fantastic. My only worry with it is if a zip tie or some little debris come down the the tube from the engine compartment they could stop the ball from closing completely. I check that area every now and them to be sure it wont be an issue on the water.
Try versa plug max first. But leave your flap on.Thanks everyone. I found my e box was full of water causing my no spark after killing the ski even if it ran for an hour. It has a newer seal and has never done this before. My scupper holds atleast 1" of water in my hull regardless. I'm going to go thrust ball scupper conversion any reasons not to? Versiplug max rickter instead?
Any suggestions on where to get a well made taller pole pad for an FS2? Does rickter make a taller one? Do you just cut the rickter one off and tape, scuff and contact cement the new one? Thanks
Did not know he did those! Looks good!!!!!!FRI Custom Rickter Style Hydro Turfed Impact Pad - Yamaha Superjet, Krash Etc | eBay
Find many great new & used options and get the best deals for FRI Custom Rickter Style Hydro Turfed Impact Pad - Yamaha Superjet, Krash Etc at the best online prices at eBay! Free shipping for many products!www.ebay.com
Freeride Innovations does good work. I got a custom pad from them and it's nicely done.
That looks bigger than 4 maybe 6"?View attachment 416926
showtime freestyle can make you however tall you want .
8” was going to use for a super flip style fixed steer conversion.That looks bigger than 4 maybe 6"?
