Super Jet Riding after ski injury
Ohio
With me it was a the shoulder at Daytona...separated AC....it will never be the same and I still get kinda twitchy if I even think about nosing in to the bottom. Just make sure from here on out you are in deep water! And if you go to freerides ask where it gets deep.....like over 15' IMO. I never want to hit bottom again! Not even on my soft sand here at home!
I was like 35 or 36 when I trashed a knee in Daytona but that healed up pretty quickly and doesn't freak me out like the shoulder for some reason. It should cuz it was bad but for some reason it feels strong and I tend to forget about it.
Not a bad thread to consider if your the main provider for your family and self employed. Ive had a few tweeks..... Strained knee on crutches a week and currently have some bruised ribs .... It seems to happen on the Last set. I have now decided not to ride the last set.
One a serious note.... I have decided it's the risk you / we take while living an passionate active life style. It can happen wake boarding , riding a mountain bike etc. I'd rather take some risk and suffer some injures than live the sedentary mundane life I see so many live around me . It's not a dressed rehearsal boys...... THIS IS IT
JT_Freeride
John Tetenes @Jtetenes
Long Island
August of 2012 I was being an idiot and subbed my ski in less than 3ft of water I was going maybe 10mph and I vertically slammed the ski into ground my knee took all the impact It hit the handle pole so hard that it snapped it at the top while the start stop switch went behind my knee cap. I couldn't walk without falling to the ground for 2 weeks. And no riding for 2 months. The next season came and I rode again but I was so afraid to sub the ski even in deep water it must have taken me about a month to finally do it. It took time but then I started to get back to my crazy self out in the ocean and not caring until one day I drilled bottom of a nose stab thankfully I didn't get hurt this time and it was a small reality check when the nose of my ski was cracked. Since then I haven't hit bottom again I will not sub or nose stab in some what shallow water.
modularjunk
day dreaming
Long Island
Definitly take it easy and work your way back. Do what feels comfortable to you and dont try to push your self to fast and hard bc if you dont have the confidence to do the trick it could up end that you get hurt. Your heads gotta be in it. Get back out there take it slow and see how it feels. start small and work your way back to where you were give it what ever time you need its only a sport for fun. Being hurt, bills racking up and debt isnt fun as you know.
Quinc
Buy a Superjet
California
I have done everything from dislocating both knee's(knee completely out of the socket and my foot pointing backward), to breaking my ankle. Key to getting back out there after an injury is to take it easy at first and depending on the pain you need to work through it. And tell yourself not to be a puS$y. The human body is incredible at healing and you will be fine. I would go see a Rolfer, Active release, or trigger point therapist until you get all the scar tissue worked out of your wrist and gain your movement back. You should also lift weights, it is good for boosting the wifes/gfs libido as well as making you less prone to injuries. http://www.totalhockey.com/product/...8-2/?dummy=1&gclid=CKH63beJjb0CFZSPfgodKY4A5Q
My last ankle break:
Thanks for the great replies guys!
Just to clarify I didn't hit the bottom. I was out past the break, jumped a wave in my first nose stab of the day and came out of the footholds, and held on to the bars and slammed onto the ski with all my weight above me
Vumad
Super Hero, with a cape!
St. Pete, FL
I went to a massage therapist with pain between my shoulder blades. She told me it was tight chest muscles, work them out, and I have been pain free in that area for years. I truly had an epiphany about body function. There are some other things to consider about the injuries that most people don't consider. I can safely say that because until recently, I had not considered them, but they are adding up...
When you get injured, you can't use your wrist. You must keep it above your heart in the beginning. Being outdoors in the heat makes it swell and increases the pain. You can't use the wrist or anything attached to it. It causes depression. All of which cause a sedentary life style change.
Your apatite doesn't change as immediately as your injury occurred. You will gain weight, ore more importantly, shift body composition from muscle to fat fairly quickly.
Rehab focuses on the injury, so in the case of my wrist rehab, the hand, forearm and bicep. It does not focus on the shoulder, core, legs, etc.
It is important to recognize how this impacts behavior habits and body function. (I don't say understand because we all know how the body works).
During the time of recovery, about a year after the injury (because recovery doesn't end when we regain majority function of the injury), there are some major changes we must consider. We stop using the wrist, but we guard it by keeping it close to us at all times. We pull it into our chest and minimize shoulder movement.
Rehab hits the arm, but ignores the chest, traps and lats, which have also seen reduced mobility. We have compensated by only using our opposing side, which retains full mobility. The tight muscles around our right shoulder pull our spine closer, and without close attention to our posture, we will slouch toward the tighter muscles. This may lead to a tightening of the muscles of the neck and lower back, when they tighten, they will also begin to affect the hip and legs.
Being sedentary will result in more sitting. Our hip flexors and hamstrings tighten while our gluts atrophy. This is a huge deal for people who sit at work and now have to sit at home. If you cross your feet, or in my case, cross one foot over the other knee, you can expect to see a shortening of the piriformis, sartorius, and opposite side QL. The opposing muscles will weaken. There are still other factors like neuro functioning and response rates to consider.
This is just a tip of the iceburg kind of thing. True rehab is going to be much more intensive than what you get at physical therapy. All of us are out of balance and must make a conscious effort to maintain that balance. Those of us that are active in these sports must train outside the sport. Those of us who have been injured absolutely must recognize the full body impact of those injuries and work even harder to get back to where we should be. They only work on returning function to the injured area. Balance must be restored through an independent effort (either guided or self studied).
Just for the record, when I talk about balance, I am not talking about my chi or some universal power. I am an analytic thinker. I am talking specifically about body function.
Disclaimer: This is based on my own personal experiences, self-study and research.
My doctor told me when I shattered my foot 11 years ago that I was young and would not need rehab. Now that I am older, but still young for this sport, my body is less able to tolerate the compensation. My issues of muscle imbalances are probably more due to my foot than my wrist, but the inactivity from school and my (more recent) injury increased these issues. You should see much fewer issues with your wrist injury than I did, however, I believe that you will be effected in the same ways to at least some degree.
@IWannaYama
My most recent injuries are a broken foot two years ago and a broken tibia like 5 years ago. The tibia was from a really big reall flat landing on a flip in the surf. The foot was a foohold injury on a flat water roll. I still do flips, but haven't done a real barrel roll in over 2 years. Even on my flips I am pretty nervous about flat landings now because my knee is still a little messed up. As much as I love doing big tricks, I am 38 and want to be able to walk when I'm 68. I can do an occasional bigger trick and do a bunch of surf riding and go home walking.
Dmac80sc
Here
This is a bad thread! I thought people never get hurt riding jet skis. ;) It is only water, it isn't suppose to break people.
Last year I broke my jaw in a bicycling accident. I got hit head on my another bicyclist whom wasn't paying attention. I put my shoulder into his face went over the handle bars. Broke his noise and he got a wicked concussion. Then it was a long 8 weeks of being wired shut and loosing 40lbs. Took me from memorial day weekend to labor day to gain weight and muscle back from a liquid diet. Took me untill mid July to get back on my mountain bike and ride the trails. Try and run or hit the stationary bike and anything else to keep yourself fit. Mentally it takes time baby steps.
Sent from my SPH-L710 using Tapatalk
I have lost about 10 pounds since this. (not that i needed it). Its funny how when I COULD have worked out I wasnt in the mood to, and now that I cant, I want to lol. So yeah ive been doing some running lately. In therapy we started strengthening exercises and I have about a 58lb grip strength in my injured hand and 110lb in my other. My main goal right now is to be able to do a push up in 1-2 months as I will be doing a physical test for law enforcement agency. I think I will take the advice of others and wait until im more established and look into aflac before I start riding hard again. Either that or sell the ski and buy a flats boat :) :(
Vumad
St. Pete, FL
Just curious is there an infraction limit? I don't want to get banned. I need something to do while I'm at work.
Yes. There is a scaling limit based on frequency. X amount of infractions in y amount of days = z amount of time banned. Use the site info sj forum for any other discussion on the matter.
WILKEY
SO FAR CHANGE SUCKS!!!!!!
Grade 3 ankle sprain for me last Saturday. Huge flip that was perfect in every aspect. Came to nose it in and the ski shot out from under me and didn't nose in like I wanted. First time that's ever happened. Will be the last two I'm done launching these 8+ foot waves like a mad man. uploadfromtaptalk1394650971976.jpg
Delaware
saw that cankle you're sporting Wilkey, ouch....
knees and ankles can only take so much, the young guns that go balls out in all these extreme sports are going to pay for it when they're older.
Tuscaloosa, AL
Yes, there is, Think I actually just gave a warning. best way to not get "Autobanned - (when you get to many points from infractions it automatically bans you) is to not cross the line.
Think before you post.
