About how many hours to install rocker nose and shorten tail... ???
Also... minus paint... about how much material is used ( cost wise minus rocker kit )
I am swapping out parts from my SN into a AM hull... might play around over the winter in NC and convert my SN into a rocker... then sell for top dollar
I have an X2 I could lend you/give you but I live in Charlotte, NC and not sure how I could get it to you...know anyone going to the Southern Fried Freeride?
I can sell you all the materials for install. Rocker nose shouldn't take more than a day or two. Tail mod could be like half day unless gutting tray and redoing all that good stuff which would take a good 2 to 3 days work. Materials including epoxy resin and biax would be an extra 175. I even draw cut lines on the glass for every piece and layer to do the job
Good move Jamie, Carter is the innovator when it comes to front and rear mods. He sets the standard for others to imitate but nothing beats his design and quality. 701 Pilots in Aus, Japan, NZ and the UK all run Carters gear. He knows his stuff and can put it through its paces as well. Look forward to your build .
