thanks for the compliments everyone.
forgot the camera at home this morning, otherwise i would post up pics.
last night i got the following done: handle pole bracket / tubes, hood straps, motor mounts, exhaust chamber mount, gas tank, tray sanded for turf (thanks Bobby!)
this will be my first year running a waterbox with the powerfactor pipe (finally) so i was not sure how i was going to plumb everything and why i stayed up so late to get everything in the engine bay mocked up. overnighted a 45 degree 2.5" coupler with 10" long legs that should take care of the waterbox to thru-hull tube. also ordered matching new chamber to waterbox and manifold to chamber couplers (all gloss black). should all be here tomorrow.
the motor mounts are what took the most amount of time... i tried "couch" motor mounts, and even spaced all the way apart on both sides of the hull, the motor sat to high and would not line up right. the ONLY way these would work, is if i drilled the holes on the intermediate housing bigger and moved it up, but this would have put the driveshaft on an angle. this is doable, but something would have to be done in the pump area so the pump would stay "angled" when torqued down. i opted to Superjet motor mounts (OEM). this is what X Scream recommends anyway as the urethane is harder overall. the problem with them though, is on riders left, the rear of the motor / motor bedplate hits the hull. i had to shim the back left corner at the mount... only way this was going to happen (i can barely get a stacker of paper through between the motor bedplate and hull). plenty of room though in the front between the motor bottom of the hull like discussed about in previous threads. the motor will probably hit / rub on landings and what not, but is what it is... we'll see how things are looking after the first ride / shakedown.
tonight, we are turfing the tray. also everything minus the handle pole setup will be removed again. then all bolts / mounts loctited and secured, turf glued down where motor might possibly hit, turf glued down where gas tank sits, and underpadding glued down where the waterbox will sit. once tray is done, put the ratchet strap on, install hood seal and crank down the hood to let setup overnight.
i am hoping to have it buttoned up Friday, and depending on time, maiden voyage late Friday evening, or Saturday sometime.
i want to leave the motor out / unfinished until the pump is done, which i cannot wrap up until Friday as i am waiting on a spacer to run between the impeller and pump per X Scream's guidance. so pump in. hull flipped over and motor buttoned up.
brad - regarding paint, check your txt(s).
joe - hell yes, i'd love to see them side by side.
