Custom/Hybrid Roo's Superfreak
Roo
it's all good
Roo, are you certain that you don't have a vibration under the hood that just transmits through the ski and feels like the driveline? It would make sense that it only did it under load.
I did use regular silicone to smooth over the joint between the pump shoe and pump.
99.9% sure it is coming from the firewall/bulkhead and back.
most noticeable when on a AC Racing beach stand in the water - you can really hear it towards the rear of the ski.
ever sucked up a rock in your pump and listened to it play ping pong? that is the best analogy i can give, but minus the rock :) heh
i have a new midshaft/housing and motor mounts i will be installing when everything goes back together... fingers crossed.
silicone... basic RTV?
my motor and midshaft line up perfectly btw - slides together with no effort.
hmmmm that statement is contradicting...
exhaust side?
In my freak I get around 500ml of water in one day riding (only from the exhaust side)<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
Roo
it's all good
Wednesday I went out, and for the first time since I owned the Superfreak, the water was GLASS. Not a boat or ripple, period.
Two observations:
-I LOVE the way the ski handles during high speed turns - the unique design Tem did at the rear of the ski at the bond line really makes a HUGE effect in handling (where it fattens / flairs out). If your turning left, put ALL your weight on your left foot and pin it. Same goes for the right.
-I need a different prop or bigger pump (or both) - I was spinning the prop EVERYWHERE. Currently running a 145MM Setback w/ 13/19 prop.
Roo
it's all good
I love this hull :arms:
I'm no pro - just a Joe, having fun :cheer2:
I hear ya. Flips are easy, it's just a mental cok blok.
Once you get over that, you'll have no problems
Roo
it's all good
Quit playin on those ponds and bring that ski out on the lake next summer. You know where to find me. Nice ski buddy.
haha i know right?
problem is distance... need a bigger gas tank for st. clair.
2 gallon + 1000cc = not going far.
right now my xs1000 is getting rebuilt.
i dropped in a 701 61x into the superfreak hull and man it still rips like crazy!
working on getting the bottom end dialed in a little better.
hope to have a second 'freak built for next year as backup / st. clair riding.
sxi steve
Life's short, have fun.
Clinton Twp, MI
DNR launch at the end of the North Channel (near Deckers) + Ridin at the end of the North Channel hittin big boat wake = Roo.
Hell, we'll drag you back if you run out.
Roo
it's all good
we'll be prepared for next season. i don't want to be "that guy" getting towed back because i ran out of fuel! heh
this will be season #2 of NOT hitting st. clair - not good!
i want to be able to cruise all over and experience st. clair to fullest like back in 2006 when i was out there all the time with you guys.
