Alright I guess. I've got my mixture screws turned past like 2 turns and now it seems to run pretty darn good, but I don't like how far I have to open them. It was doing some funny things the first couple test rides.. With two turns out on both right when I launched it, I was only going up to like half throttle ish and it had perfect brap, and then when on plane going up to. Like 2\3 3\4 throttle it had great power too and this was like all within two minutes, then it just died. I could get it running for a couple seconds with choke but then it'd die. Took it to the pier, adjusted some things, rode it with hood off and it would do similar but also a little longer but just die right out.. It wasn't getting enough fuel. So then my dad came out and we raised the idle, then adjusted the low speed out until it had good off idle power, and then opened up the high speed screw up to 2.5 turns. I'm not exactly sure what the low speed ended up at. But it was wierd because after this, it ran really good. It's like with 2 turns open it didn't have enough fuel to even get going.. Somethings gotta be wrong IMO. Then we richened it out to like 3 turns on the high and I rode around for a bit and it was pretty good, but you could tell it was boggy after you landed a jump and had the nose up and you were getting back on plane. It ended up getting worse until it wouldn't go at all... I pulled the hood and the cooling line to the stinger came off so it was an exhaust leak that was giving me quite the bog.. So Idk if it was that giving me the bog and the carb at the same time.. Cuz now at idle with the hood off it accelerated really good, but with the high speed turned out to 3ish turns.. It runs good but I don't like how far out the screws are and I'm using the recommended b pipe jets and spring.
Onto how my cooling hose came off.. And details about my cooling. My stinger hose got hot enough to soften the hose for it to fall right off. Here's how I'm running my cooling, and zack at php told me to run it exactly like this.
Two lines into mani, tee both outlets on the head. Rear cylinder, angled part of tee to bottom of midpipe, then straight part of the tee to pisser. Front cylinder, angled part of tee to the stinger with a restrictor(drilled out seat) and then a flow control valve and straight part of the tee to pisser. Then a hose from the top of the mid pipe to a pisser.
My cylinders get cooled perfectly and have equal constant flow and a good temp. The pisser off of top of the mid pipe doesn't flow as much as they do at idle, but when you get on the throttle more, it starts to flow decent. Is that how it's supposed to be? And it's super hot too compared to the cylinder pissers. It like flows but only when you get on the throttle..
I wouldn't have noticed this before because I wasn't riding it for an extended period of time. After like 15 minutes or so of riding around it finally got hot enough to melt the turf on the chamber, hood tubes and then the cooling hose. Luckily the high temp couplers seem fine. Since the stinger was open exhaust was leaking so it ran fine without the hood, but when I gave it some gas, no water came out of that line and I had the fcv opened up almost all the way just to play it safe.. And I couldn't see really any water making it to there. It's like all the flow is going to the straight part of the pisser and none to the angled part. I don't know why my pipe is running so hot because I don't believe that is what cools it.. The line going into the bottom of the mid pipe is what should cool it right? But it doesn't seem to be. Both the lines coming off of the tees don't seem to be getting much pressure then.. And I'm doing just what zack told me to do..
Confusing...
Sent from my XT907 using Tapatalk
