- Lake Orion, MI
Next year Id like to experiment with running the powerfactor chamber wet as I have heard it really improves the bottom end response. I already read the entire thread about this issue, but got mixed results, answers and then it turned into a debate and got off topic (lets keep this on topic). Eventually, I will add pics/descriptions from my experiences to help those in the future.
Things I understand from my research...
For me it will be a Carbon DVX hull with PHP 898 (pump gas) and skat setback 148
Thanks!
-Bobby
- Jetting, Prop and nozzle must be matched/tuned specific to my setup before any true results can be felt
- Will need to drill/tap my powerfactor manifold to install a spray bar
- some fittings on chamber are plugged basically eliminating the water jacket (some cut the jacket out completely - too much work for me)
- what filters are used before the jet to keep it clean
- good starting points for the jet
- clear water routing diagram
- how the waterbox is cooled
Thanks!
-Bobby
