Philip Clemmons
Owner, P&P Performance
- Richmond, Va
What about the little 900s?50 lb hulls 1200cc motor....... flatwater.
I wonder why the top boats at world finals (I'd guess 10 pro and 5 AM) all had dry setups?
Must be something to it
Scottie. You know as well as anybody, more so. That the power delievery of these 1000cc+ motors is different than that from that of the older 701-785cc motors that we use to have to use....... Back when we (I still run one) had the smaller motors. We needed the power down low. really low to help with the tricks.... Roll, Land, stab the gas, get moving. transition into the next trick. Nose Stab/Bronco. Get up get moving...........etc etc......... Now. your time between tricks is either extended or you are doing combos where you are getting on the gas before you even hit the water again keeping the RPM's up higher. I know Peter said the difference between his first DVX and his new one is the tuning is such that the power is coming on a bit later now. But it is working.I was thinking the same thing. What is funny is, for YEARS I sat hear listening to people say dry pipes were 'race pipes' and didn't have bottom end, all top. Then the PFP came out and every swinging d1ck out there said it was a game changer. Now everyone is saying gotta go wet, lol. What is the trick set up on this site changes like the direction of the wind.
SM
.....And there goes my interest in this mod. I listen to what he^^^^ says.
No doubt that Zack knows his stuff, but I have been tuning my ski with Phil's advice from the get go. I stick with one person per motor. Never pick and choose different advice from different people. Stick with one all the way. It's like the movie Ghostbusters, "never cross the streams"I bet you would be one confused person if you rode Zack's ski with his wet setup.
Its not rocket science........... Well ok, yes it is. But you get good results with either setup. It is all just different methods of tuning and where you want your power to be.....
We need a good old fashioned "tune off"!
And yeah, not to be a P&P nut swinger, but I've ridden enough different set ups now, that I trust what phil says when it comes to my skis.Still 50 lb hull. And nothing counts when you tune it cause you make a 900 feel like a 1200![]()
