I'll let Phil chime in, but on his set up, idle flips were a breeze on his dry pipe, but not when it was wet...Ha I'll take my wet version over the dry anyday.... tested back to back.....
I have a boat you need to ride if you want immediate arm ripping power a d @bigkahuna can back me up. It's honestly in the pump tuning. I purposely set it up slightly under propped to demo the low end snap of the 1105 at wf. The prop before that changed the whole attitude of the way the motor hit. It had no other changes but propping it down. Out of 30 plus guys that rode it only 2 came back in and said it felt under propped lol. This boat will be in va this weekend @masterblaster hit up Erik or Phil to test it out.I bet if we took a poll of what kinda power curve would you prefer? Almost all would put a check in the box for immediate maximum off idle torque and power that is linear through the milli sec you pull throttle all the way through upper mid and sac a bit of top end hp All but top pros. That's what injection timing the pipe wave provides. The same reason the b pipe was so popular for so many yrs before combo surf /flat water hull builds became possible
You guys coming down for the whole weekend? I'm trying to kick this cold and get out there Sat morning.I have a boat you need to ride if you want immediate arm ripping power a d @bigkahuna can back me up. It's honestly in the pump tuning. I purposely set it up slightly under propped to demo the low end snap of the 1105 at wf. The prop before that changed the whole attitude of the way the motor hit. It had no other changes but propping it down. Out of 30 plus guys that rode it only 2 came back in and said it felt under propped lol. This boat will be in va this weekend @masterblaster hit up Erik or Phil to test it out.
We won't be there. But there will be 2 havocs heading to get looked over then off to sponsored riders for the winter season until their hulls are done.You guys coming down for the whole weekend? I'm trying to kick this cold and get out there Sat morning.
Seriously.... I didn't know running a dry vs wet pipe setup could cause so many different opinions. I thought we all had different boats and we could do what the F we wanted to it..... everyone has different riding styles and like the power in a different spot. I'm not one that likes to "wait" for the power when it comes to surf......Its not rocket science........... Well ok, yes it is. But you get good results with either setup. It is all just different methods of tuning and where you want your power to be.....
thats another way of saying it..lol after all we are talking about fractions of a secondPart of the reason the wet pfp is popular is its easier to tune. The pfp takes a bit of work to get it hitting where you want. It's easy to bolt a pfp on and be disappointed with the powerband. After injecting the pipe you suddenly have a bunch of snap.
My experience is you will never get "pro advice" here unless you are a 1%er
