there was alot of detailed pics in the other thread i started about this same thing.
Dag..you are saying what ive been thinking all along.Make the pipe work for what you have NOW quickly.. then when your builder or tuner wants u to buy 3k of extra stuff if u have the money go for it and change or remove injection. Some guys posting here act like all these people that have been shipped these diff motor setups all over the country and world for that matter,can just ship their ski and fly to the VERY few tuners mentioned and then pay them to do it...if they are in your neck of the woods fine,but this is rare.
Anyone that knows 2 strokes knows their is no mod that makes more diff then adding a PROPERLY tuned pipe. It just so happens we use our pipes in the water and we have it readily avail for our injection pipe timing use,sleds,atvs,motox dont have this cheat avail to them. The water injected bpipe was popular for just this reason,no one wanted to use dry pipes and burn up couplers and struggle with tuning them and clog jets in surf,that is until people starting water injecting them and getting them to work much more easily with pre filters even in surf... then the rrp injected pipe came out and it was off to the races for big lay down pipes when larger tanks were made to accommodate them. Sure you will lose a few hp in the up top rpms when the heat factor is higher and changes the wave speed in the pipe,but the torque you gain in low through upper mid is sick.
IF you want both u can get tinkering with a reverse flow control valve in place of msd elec injection that works well and is easily made from billet fuel filter housing and rubber ringed washer,but tough to keep consistently tuned. it is a valve that allows water to flow through up to a certain pressure,then collapses the spring and allows washer to seal. pressure and rpm are equivalent in this application. The problem in a reverse type valve is the spring gets completely collapsed quick and hard with every brap. I think if a larger housing and more heavy duty spring was used it would be sustainable with less spring tention tinkering long term. With as much on off throttle brap as we use in most cases if the stinger is run just a bit more wet,the pipe stays cool enough run like this. OR if you are sustaining rpms alot,you can run the pipes water jacket with water also and use it as a wet and dry pipe at the same time. The best of both worlds. And still have the tunable wave lenth and much less headache tuning.
