wsuwrhr
Purveyor of the Biggest Brapp
- Alta Loma, working in Upland
the inside can be masked, the oil will prevent corrosion, its the outside than needs to be delt with.
Agreed
that right there is what wet dreams are made of.
I was already planning on making a cover so we could build a complete billet engine, something about that is just trick to me. Billet mount feet are next.
Brian
Anodizing is done for a lot price, meaning to anodize a single color for one part is $50., for ten parts it is $50., for 30 parts is it still......$50. Kinda of a racket if you ask me, but it is what it is.
Brian
Done then, I will put an oring for the mag cover seal
The cranks will come from Crankworks, we deal with them exclusively, their quality has never been a problem and Phil takes care of us if we do. I paid a HEFTY pricetag for the intital crank, so I think the crank will come from SB Products as well. I would hate to think that I paid all of the R&D to develop that crank so he can sell it to everyone.
BTW, the crank will be somewhere around $1300. slightly more than a 12MM stroker.
Brian
It also needs a bushing for the stator.
Brian
O-rings around the intake and cylinder. Interesting idea. The intake would be no big deal.
Initially, what about between the cylinders? Around the outside would be easy, but the space between the cylinders might be too small for two separate o-rings. I would have to have a custom one peice o-ring made for that.
One problem is with annodizing(after the fact) is the main bore will need to be held oversize to do it correctly, anno will make the bores slightly smaller so this has to be taken into account. Other than the main bore, nothing else is real critical as far as that goes, but that would be a big deal as the cases would be "tight" around the crank. In my opinion, if the custumer wants to annodize them, they need to be done before they are shipped.
I am interested in how the case girdle kit is set up.... are all of them... not sure how that would work...
these rib sections can you make them flow water through and put an o-ring on it so we can use it as a case cooler
Ok i thought the bottom plate on the girdle would be a solid plate
and the ribs would be in the cases
Hvae you lightned up the girdle plate with cutouts as well
can we see a picture of the bottom of the engine please
ok i may need to explain myself better????
It is.
The ribs are machined into the cases, part of the case itself. I am trying to get down to 5 lbs heavier than the factory case. In it's current state it is 6 lbs heavier and plenty rigid.
Brian
ok i may need to explain it better
if the ribs are machined into the case
you built a girdle for the bottom of the crank case
is this a solid piece of alloy
if so there would be an air gap between the ribs even with the girdle plate on
could these be joined together and water pumped through them using the girdle plate to seal them off
ahh ok thanks
I was looking at the pics up there and i could see a line and i thought that was a seperate plate under the bottom case but it must be a machining mark
Never mind
These things are so awesome i can see myself with a set of these
yeah bolting on a plate to the bottom would be easy
I like the idea of the groove in the cases for people that dont run oem front covers
but i guess you will sell more front covers if you put it in the front cover
Able used to anodize there cylinders black , being black hard anodizing they never corroded and always looked good
That would be my choice
Please dont oring the case/ cylinder surface
When ever i build and engine i get into there with the grinder and if i break through a groove i will end up having to jbweld up
Its looking good i cant wait to get my hands on a set of cases
