Super Jet Sj 1200
Vumad
Super Hero, with a cape!
St. Pete, FL
Overall it was a great experience. I don't want to discourage anyone.
That's fine, but can you explain the complications you had? I would like a SXR hull with a GP1200 motor but more realistically may end up with a SJ hull. I also considered a custom hull with integrated sponsons to allow more space in the engine compartment. I'm interested in your complications so I can plan accordingly. I saw the exhaust routing was an issue and integrated sponsons would have made more room to run the pipe to the waterbox. Etc etc.
I've been on a stock SJ for about 2 years. I just upgraded it to a fully limited SJ. I know that by the end of 2 more years I will want more. I want to start working on a plan, and since it will be complicated to move on from here, I want to start working on it now. I have a 1200 on the bench that is bad that I have been saving for this project. I was thinking of getting a hull for and start working on slowly. Any advice and complications you can explain in detail so I can avoid them from the beginning would be great. Honestly, I think I'd like to work towards a GP1300R motor, but I'm not sure that is realistic.
tshank123
Yo hablo ingles
Vegas
Vumad, my guess is that it was a tuning nightmare with that 2" exhaust, just like people said it would be. The idea of having to rip it back apart to run 3" was too much for him.
Vumad
St. Pete, FL
I got better performance out of my 750 when I upgraded to a SJ waterbox and B1 outlet (all 2"). I just don't think those motors can run that great being restricted like that.
I did plan on maintaining the 3" exhaust on my 1200, if I ever get to build it.
tshank123
Yo hablo ingles
Vegas
Its just another reason why people opt for Kawi conversions on blasters and sjs. Its already 2" on a kawi tripple so the exhaust is much easier to deal with, plus the chamber is so much smaller.
Vumad
St. Pete, FL
But doesn't the 1200 make a lot more power? The 1100 kawi is rated for 120hp factory and the yamaha 1200 is rated 135hp factory. Who knows if those numbers are right. The Yamaha came with a 155mm pump and the kawi with a 148mm pump, so it's hard to say which is a more powerful engine. The larger pipe and exhaust may be a waste of space or making more power? Does anyone have any knowledge of a kawi 1100 vs a yamaha 1200 side by side throughout the RPM range using similar set ups, say a B1.
tshank123
Yo hablo ingles
Vegas
Thats an ongoing debate. I've had plenty of debates with people on the very subject. I wouldn't trust the factory hp numbers for this one though, they're both pretty close to each other. I'm a yamaha guy myself, and my blaster 1200 holds its own against kawi blaster 1100s. The 1200 with a stock pipe makes its best power in the high 6000s, whereas the kawis like to run in the high 7000s.
