Just did 3.5 hours of work on the ski tonight. I got some sanding done here and there around the entire ski. Figured it was time to pull the pump shoe and when I did reading on that everyone said it's hard to do and will come off in a million pieces, well it took 5 minutes and is still all 1 part and could easily be reinstalled. Later down the road my new blowsion pump shoe will go in, sometime after paint. After removing the pump shoe I move up into the tray with the plan of finishing up everything inside so I can build the tray and get ready for footholds, that did not happen as I envisioned. Both cooking lines were loose and would have had leaks at each end, same with the steering tube. So I ripped all that out and will install some new cooling lines and seal them up tight, the steering tube will be cleaned up and reused. And finally I got my (DIY) scupper installed. That finished off my night as the 5200 I used to seal up the scupper tube on the inside of the tray take 2 days to get tacky and 7 days to cure. Oh and I also got my carb back, I had brought it to my buddies dad who build custom choppers to remove the broken bolt and he was able to drill it out, tap it larger and lathe down a Allen bolt to use as a hold down for the seat of the needle and seat. Sorry this is all the photos I took while working on it.
