- Edmonton, AB
I've setup 3 of them, all will no issues. Make sure you press the bearings in properly
easiest way to do the install.
bearing #1 in freezer, stator in the ovenat 250* for 15 min. remove both and install bearing into the stator.
stator and bearing one in the oven again, bearing 2 in oven, driveshaft in freezer. remove bearing 2 and driveshaft, install bearing 2 on end of shaft.
bearing 2 and shaft i freezer, remove shaft and stator, install shaft and bearing into stator and bearing 1. tap to seat, let equalise.
I have done this for axle gears, uniballs, and drive bearings. no press needed if your quick.
Did you read my thread? Lol
http://www.x-h2o.com/threads/137372
That method worked great for me. Heating and cooling is the way to go.
This thread broke my heart. I was set on getting an Solas mag but now I'm scared
All u have to do it go to a machine shop and give them the pump and bearing and tell them to measure it and if its tighter than 1 thousandths press fit then tell them to get a flap wheel and make it a 1 thousandths press fit and you will be fine it should be around $30 easy peezy
Sent from my SAMSUNG-SGH-I727 using Tapatalk
