- Saskatoon,SK
Solas does not give out an engineered size or spec. I will give out my opinion on the correct size required since my background as a machinist/millwright/mechanical consultant and amateur gynecologist for 25 years allows me to do so!
Some simple rules are followed to come up with the proper size,
1)the rotating part gets the tight fit, this is the shaft, my opinion is it should have a m6 fit at 25mm(.9851"/.9846")
2)the static part (pump) gets the loose fit (clearance) there are 2 fits here that will work but the first one H7 52mm(2.0472"/2.0484") leaves no room for error as 2.0472" is the actual bearing outside diameter and most machinists will shoot for the smallest size of the tolerance.
This leads me to G7 52mm(2.0476"/2.0488) as my favorite, it allows .0004" clearance which will still be required to be pressed in even though it is a 'loose' fit. The loose end of that fit may allow more bearing creep which could were the pump prematurely so try not to go there. If you chose the tighter H7 fit a C3 bearing will give a bit more allowance, but a standard SKF 6205 bearing is rated at 14000 rpm so it will work fine if all sizes are correct.
Just my opinion, but I do this stuff all day long everyday (unlike the gynecology part, she picks which days!)
