- Jacksonville, Fl
That's what geek did on his and I'm planning on doing on mine as well.
Do you want your screen-name changed? I can take care of that.
Yes I do want to change my screen name.
Someone Todd knows in S. Florida on the west coast I think. He does alot of motocross engine cranks but does the watercraft cranks also. I will find his name for you. Said he took off around 1 lb. and it balanced up perfectly.who lightned the crank?
I used West Epoxy resin with 206 hardener and 406 filler and made it real thick so I could apply it by putting it in a freezer bag and cutting the corner, (piping it on) kind of like someone who would decorate a cake. I couldn't find any empty caulking tubes.
Whats up Mike, Yes I am. It is going the painter tommorow. The engine should be ready next week. I had a guy name Todd La Chance (TLR Performance.com) build me a new engine. He had a 61X cylinder laying around and wanted to use only my cases and completely redo everything. He has had the crank lightened and balanced and I will go with a single carb,lightened flywheel etc.. He built alot of freestyle motors in the 90's for Wamilton (Rick Roy, Jason Stoyer) and Riva. He is living in Lake City,Fl now and does 4 stroke motocross engines. Sorry I missed you last time you were up here.
Turfed it and installed all of the hardware. Off to TLR Performance to install the engine in the morning. Don't have the money for an RRP handpole just yet so I will use the stocker until then, hopefully it won't break.I was going to put the motor in on Thursday but will have to wait until Saturday. I may be out on Sunday. Hopefully will water test on Saturday and hull test on Sunday.
