jetskidkid
Round nose's rule
- dirtbiking, CAlifornia
All Bout Backflips, And Barrel Rolls, Ridin The Waterdawg 8 &12 Hundo!! Ride On Brotha!!
sure why not. just need new front mount locations and exhaust.here's a question, can a 701 be rigged up to go into a GP? If so my GP "family" ski, just might get a downgrade.
Man I'm diggin this set up a lot!
So I assume you can lighten 800 flywheels too ,right?
So this set up with a milled OEM head and a lightened OEM flywheel would sick!
or decking the bottom of the cylinders to lower port timing.
I'd use stock 701 exhaust.Thank you kindly sir. What kind of stuff needs to changed with the exhaust?
Don't mean to thread jack. That setup is sick Jeff.
I'll let you know how it goes. need to figure out the mechanical compression and squish after decking the bottom of the cylinders...Even better!
I'll probably do a before and after test.
I'm sure there is a way around that...duh. Wasn't even thinking about the 800 in a SJ needing the WDK exhaust. my bad. :sad6:
hmmm, i need to go look through my couch for 1,600 smacks.
