stolen super jet - FOUND!
Status
Not open for further replies.
I will have the pole/pad shipped in the next few days. sorry it is not at the house now. Work is killing me. I will overnight it so you should get it by friday. I will let you know.
please dont pay ridiculous cash to rush it here. its enough that youre donating what you are. it cant be cheap to overnight a stock pole.
thanks!
TB
NOTHING IS EVER PROMISED
Grand Rapids, MI
choke cable didnt get shipped out today...i'm having my mom send it for me cause it'll be cheaper yet..buisness to buisness..she didnt go to work today..i didnt know she had a doctors appt. it'll be on its way tomorrow..
what do you want for one of those yami cranks???
Y
yamaslut
Guest
Hey Charlie... make a list of odd and ends that you need... I got the shims... What else were you needing??? I totally forgot what we decided on....
big stuff I have:
crank seals
reeds and manifolds (61-x)
cases
intermediate shaft housings
pump parts
throttle pulls
all kinds of bolts
trim pieces
used crank that is still in good condition
hood in great condition
a slutty modded hood in ok condition
ride plate and maybe an intake..
Rickster
Matakana Menace
Charlie, I have the new steering (bars, throttle pull, et) but no cable....
If we cannot come up with a cable, I will donate the one out of my square hull...
:beerchug:
I also have ride plate if you need one.
big stuff I have:
crank seals
cases
pump parts
throttle pulls
all kinds of bolts
trim pieces
nick, i have a list in the first post. of your list, we could use:
-small intermediate housing
-long driveshaft (if thats a pump part you have)
-squarenose bra (if thats a trim piece that you have)
-hardware for motor mounts, mounting electric box, hood latch reciever (that screws onto rear of hood).
let me know if you have these parts and ill update the list in post # 1.
thanks!
:beerchug:
hey rickster! i think we have all that covered but the steering cable. ill update the need list.
thanks!
Y
yamaslut
Guest
thanks!
I have all that except the long shaft... do you need the actuall box itself???
excellent! ill put you down for those items. i dont need the entire box. just the 2 stainless brackets that hold it to the dash panel.... i thought i had a set but i cant find them for the life of me:ugh2:
RoyalFlush@PCB
Shootin' The Crap
PCB
I have a squarenose "bra" if you need it---I can send it with the other stuff, but I would have thought you were turfing that. :swordfight:
maybe i didnt mention it before..... paul is all about STOCK!!!!
stock 650 nevertheless.
as gay as everybody else thinks it is, hes the guy towing the modded skis at the end of the day.
GUMP
i rekon
Pensacola, FL
man i'll tallk to james tomorrow if h agree to donate one his long shaft i'll take with me to west palm and maybe ship from there
h2odesperado
Pin it to win it
Charlotte, NC
i got a driveshaft thats stuck in a bearing housing that i can't get the prop off. I'd be willing to get it out of my garage but it wouldn't be till mid november.
Y
yamaslut
Guest
ok... stuff I collected and threw in a box last night
  1. the mounting hardware for the E box
  2. several different sized shims
  3. the plastic wire/cable holds that rivet to the hull (for routing)
  4. intermediate shaft housing
  5. various sized SS hose clamps
  6. the 4 bolts that mount the bedplates to the motor mounts
  7. I think there was something else.. I can't remember
I will toss everything in a box w/ the hood and send it down tomorrow.
I'm gonna send some flyers too in that shipment... Maybe you can get some in Steves shop and some local shops...
GPnVB
wavejunkies.com
Sorry to hear this. I was in Charleston on the 14th and saw one that looked very much like this behind a silver taurus or similar. I pointed it out to my wife saying "check that out, you don't see them like that very often anymore". I then went on to talked about the stock graphics and rattle can paint jobs.
Had I known I definitely would have tried to get the regi numbers off of it, just in case. For some reason it struck me as odd.
ill definitely do that! thanks nick!
desperado, im hoping to be done by mid november but anything is possible. thanks
i just looked at the pump i have and its from a venture or raider and has a different wear ring section :(
wear ring has just been added to the need list.
on a positive note, i found a start/stop switch for it! :)
Status
