customride0105
- sterling va
if the hoods lite there should be one made so you can post pics up now.. and wanta make sure my ski will have the hood with it when you bring it to ny in feb...
Answer me this, what size holes will need to be cut and at what locations to 1. provide adequate airflow for your motor to operate correctly and 2. As to locations, what is going to be the best location for proper airflow with out letting excess water intrusion?
I don't know if Dan has this information in the instructions but isn't that part of the fun that's involved with building the hull yourself as opposed to having someone else build it to suit everyones elses riding style? When mcdog asked about breather holes I immediately started brainstorming on the best method for "feeding the beast". You could run only handlepole breather tubes. If you like tailstands but don't have the handlepole breathers, you could put the breather up in the front of the hood but if you like doing subs or fakey subs, you could put the breathers in the back of the hood so the hood doesn't scoop the water into the hull like the SN hood.
This isn't rocket science, if you can't figure out where to put your hood breathers you have no buisness building the hull.
Exactly.
Great looking package Dan!!
