- Atascocita
If I had my boat up there I would help you find it and we would find it. I have the Lowrance HDS LSS side imaging system mounted and they all have down scan now. Humminbird has similar models that you can buy for around $500 used that dont need the seperate LSS module for side scanning. Borrow a small boat and put the transducer on a pole and get it in the water. Hook up a battery to that unit and go to town. You would have probably found it by now with the side imaging/down scan. In 8-16 feet of water you would be able to see the bottom clearly at least 60 feet to port and starboard and directly under the boat at the same time. There is absolutely no way it would be missed or it isn't there...or its completely under the sand but still, there would probably be a hump. The technology is that good. I can count the branches on fallen trees in the lake if I wanted to.
When you are done with the unit put it back up for sale...This is what I would be concentrating on and you dont need water clarity at all.
Good luck, and hope you find it soon.
