So then you saturate the carbon after it has been placed on the wet surface? I'm sure you're not just wetting out one side right? That's a pretty clever technique.
Exactly, I have actually applied it to a dry surface before as well and wet it out after and it worked okay but by wetting the surface first I think you have less chance of dry spots but see what works for you.
For this build I used the same technique for the biax but applied resin to the back side of the cut pieces with the wax paper on and then laid them on a pre-wet surface before applying resin to the top. That helped big time to saturate the biax and once I was done with that I just laid the carbon down dry to soak up whatever excess resin was left before finally wetting out the carbon.
