- Argentina
Hi Romak! I´m in the middle of the mod, did you cut off the 100K resitor on the other side of the board?heres some pics of the one i did and the cheap drawing i made after the originals on pwc2day got wiped out.
Hi keefer! Did you cut off the 100K resistor ? I followed the instructions regards 50 resistors an trimpot, but cdi still limts at arond 7100.When I make the mod I simply remove the 100k resistor & replace with a 50k resistor in series with a 50k linear taper trimpot. If the total resistance falls below 50k the the circuit will not work. The fixed resistor makes the rev limiter adjustable from the stock setting up to about 8500 rpm.
@OCD Solutions. If I bridge to get the 8100 limit, would this work on a stock 6m6? Would it even be noticeable? And chances of blowing motor on WOT? My 13 yr old son rides this machine and holds it open all day over chop or jumps or anything he can find.
Leave it stock if its not cutting out on smooth water. This usually takes a ported cylinder and low pitched impeller.@OCD Solutions. If I bridge to get the 8100 limit, would this work on a stock 6m6? Would it even be noticeable? And chances of blowing motor on WOT? My 13 yr old son rides this machine and holds it open all day over chop or jumps or anything he can find.
Bone stock. And it only hits when he is jumping waves or porpoises (on purpose most times I think just to hear it rev out) Thank you. I am going to keep this part stock as well. At least until he has some better control over the throttle. He is eager to learn but likes to just ride.(on his knees just about as much as standing up) ♂️ Working on stance and carving right now. The first two days he had it all I heard on the lake was that annoying yin yin yin yin... yin yin yin yin. But it has gotten better. Leaning forward when at speeds helped a lot. Just not enough hours in the tray I guess. Already asking about that magical 701. I think all he heard when I talked about a swap was “more power and faster.” Thank you for the reply and all the work you and others have done to pave the way for us noobs to the superjet world.AFAIK, this mod works on all versions of the 6M6, 6R7, 61X and 62T CDI's.
The only noticeable difference will be that it doesn't hit the rev limit as soon, if it's even hitting it now.
Does the ski have the power to hit the rev limit now or just when the pump unloads? What's the setup?
If it's hitting it while loaded, you should prop it up some to load the motor and bring the RPM's down.
If it's just when out of the water, he needs to learn to control his throttle finger.
What do you mean connect a jumper ?Here are the pics I have that show where to connect a jumper to disable the rev limiter.
