So my next question to the gurus is will this tiny leak cause the major low end bog?
Ill be tearing down and rebuilding as soon as i get new gaskets.
I'm no guru but shouldn't the psi be dropping in your gauge? I'm sure the leak is worse when your motor is making more pressure then what you pumped in it.
-Pull the rear coupler off
-Turned that motor upside down and pull the bottom case off.
-Take a picture or remember how the seals came off
-Clean the matting surface but make sure u don't drop them inside and install new crank seals how they came off.
-spin crank bearings so they drop into the pins
-use 1211/ honda /yamaha bond to seal the cases
- Seal the starter area as well while your a it
- case 12mm bolt torque is 20 ft lb
- Bedplate 14mm bolt torque is 34 ft lbs
The job sounds hard but it's really cheap and good insurance to replace the crank seals and doing the job well, it's just takes a while to do.
Another thing you could do besides panicking when the motor runs on you while it's on the trailer by the water just back the ski back in the water and it puts a load on the motor and will shut off.
