Hogggman
Stock Sucks
- White Lake MI
I'll paint it for nothing if that hasnt been accounted for. I am 5 mintes from you Kurt. I'll check my parts supplies I have to have some of this stuff.
Hmm. Not what I would want on my own ski, but for this build it seems to fit the bill. I may have to trick it out a little, though.I'm not going through the whole thread - and I don't know the story... but there's something about Louie and a pink finger throttle.
if ya'll want this one for the build - let me know and I'll buy it:
http://www.x-h2o.com/threads/p=674439#post674439
We have a ride plate, thanks to X2 RAGS.
Still need a 6m6 or 61x stator/flywheel so I can get the motor built.
Should I send PM's to those that never sent promised parts, or post a list? oppinions?
should be there by mondayish
Is that a federal or Florida-only holiday?
:clown:
i sent my promised parts yesterday:
bedplates
stator
nosepiece
PINK
sorry about the delay.
Here's a list of parts needed. I'll do my best to edit the list as parts are accounted for.
Topdeck conversion Snowxr
Donor hull Madscientist ACCOUNTED FOR?
DASA/Lamey Cylinder Dasa/Lamey ACCOUNTED FOR
Crankshaft SBT RECIEVED
cylinder head Yamasaki RECIEVED
62T cases PURCHASED
B-pipe NEEDED
reed cages Yamanube RECIEVED
hood NEEDED
nose piece SFL RECIEVED
pole mount Danceswithsuperjet RECIEVED
hood seal The Penguin RECIEVED
ride plate X2 RAGS RECIEVED
handlepole NEEDED
steering NEEDED
bars Jetskihaven RECIEVED
pole spring Danceswithsuperjet
pole bolt NEEDED
hood hooks NEEDED
hood latch NEEDED
fuel selector big kahuna/ snowxr
primer kit jetskihaven RECIEVED
pump jetskihaven RECIEVED, but need driveshaft
prop (any stainless prop. this can be sent to impros fo repair/repitch) NEEDED
reduction nozzle Jetskihaven RECIEVED
steering nozzle NEEDED
bow eye qty. 1 from Danceswithsuperjet. 1 from jetskihaven RECIEVED
fuel tank NEEDED
fuel pickup Mike W RECIEVED
gas cap with base Big Kahuna/ SnowXr
handgrips Danceswithsuperjet RECIEVED
start/stop switch NEEDED
throttle lever SFL Surfrider RECIEVED
throttle cable Big Kahuna
steering cable NEEDED
motor mounts NEEDED
engine bedplates SFL RECIEVED
midshaft NEEDED
couplers 1 from Mike W. 1 jetskihaven RECIEVED
damper- Mike W RECIEVED
driveshaft NEEDED
battery box SXIpro RECIEVED
flywheel NEEDED
stator SFL Surfrider RECIEVED
cdi Freestylegeek 61x RECIEVED
e-box parts Jetskihaven RECIEVED
pole pad NEEDED
carbs NEEDED
air cleaner adapters 44mm Jetskihaven RECIEVED
intake stk 38mm Jetskihaven RECIEVED
misc. hardware
We'll need some $$ for supplies, like paint, sandpaper, turf, etc. If people would like to send spare parts that we can e-bay to fund other needed parts we'll do that.
contributions can be sent to my paypal SnowXr@aol.com
Current budget as of 12-14 contributions $55by: Pankakepete, XFT Lou
Thanks for the help.
Kurt
