Ok, went for a real ride on Sat... I have some ideas on my problems and would love to hear feedback.
The ski rides nose high... like really really bad. I think that because the nozzle is pushed out SO far behind the ski, that the trim is being engaged by the forward momentum of the ski.
I'm gonna make a "lock out" for it and try again. Does this sound plauseable to ya'll? I don't want to get a spring thats so strong it holds the nozzle down against this force, because then I have to pull against that spring with the trim lever. Which will result in streched cables and arm pump etc... Maybe Trim isn't for me.
I made a exhaust adapter out of PVC. 1.75" to 2.5" ID. Well it melted after riding for awhile. Which filled the ski with water, stalled the engine, and since I don't have a bilge hooked up nearly sank the ski as I tried to swim it in. Scuppers only work if your riding! Going to make one out of Aluminum, getting the parts today.
And lastly, my carb is a mess. Its loading up at half throttle. I still don't completely understand carbs etc, but i'm gonna pull it, check everything. Popoff, jet size etc. I have some numbers written down that others have had success with. Try to come up with something that will work for me.
I do have some good news. Saturday morning I cobbled together a chin pad from scratch. I used one sheet of aluminum and one sheet of staineless I had laying around. (I didn't have enough to make it out of one piece.) I didn't scuff the metal before turf so its not holding very well. I'm gonna pull it all off, scuff it and use some 9mm pad under the turf.
