One thing to think about is adding too much to the tops of the motor mounts.Hopefully you didn't add to much to cause an alignment issue.
Thanks dude! Yeah those are McMaster heavy duty rivets nuts with M8 socket bolts that I had to grind down nearly to the hex to get to fit inside the rivet area to flush up.Nice work! Did you get those drains from McMaster?
I didnt know such a thing existed!! Thats exactly what I need. Looks like I need a special tool or is there another way?Thanks dude! Yeah those are McMaster heavy duty rivets nuts with M8 socket bolts that I had to grind down nearly to the hex to get to fit inside the rivet area to flush up.
Sent from my LG-G2 using Tapatalk
I just gflex epoxied them in without crimping them with a tool. Then since there is recess space without compacting the rivet you can get the ground socket head to sit inside of it flush, plus a small o-ring.
Nice, very slick! I can see how that recess allows the screw to countersink. If you have extras you want to sell let me know otherwise I am going to order from mcmaster soon.
If you have more than 2 I'd pay shipping for a set. I just drilled 2 holes in mine
Did you glass then carbon around the bend where it mounts through the firewall?
I assumed you did I just couldn't see it on my phone.
