Here is the gelcoat waiting to be glasses over after it reaches the tacky stage.
Again, I didn't take many pics of completing the molds or the layups, so I'll throw a trick I use in for you. I cut a piece of 1/2 pvc and create my own inlet port to infuse parts that lack flat spots for the larger flanged ports available.
I also found that cutting a box up to suspend your mold is quicker than glassing legs onto them to let them sit flat on the work bench. It also gives you a spot to stuff a space heater in if you want to heat up the molds to let that resin flow nicely.
View attachment 322624 View attachment 322625 View attachment 322626
Here are the final parts popped out of the molds and trimmed up.
View attachment 322627 View attachment 322628
This is a test fit and a final turf job. Oh yeah, if you're paying attention and are wondering where the reebok pump bladders come into play, that was just a wild idea I had that I decided was unnecessary. But, in the future, if it becomes the next big thing, remember you saw the idea here first!!
And here is the final product installed. When laying these holds up, I did not use any core material and lighter layers on the inside panels. This allows them to flex open to accommodate a larger shoe. I wear a size 9.5 and even our own Georgia Jet Pirate
@Captain PegLeg was able to kick his #13 air jordans in with no effort.
Over all I like the fit and feel better than the rickter holds I've ridden. I have had a couple xmetal guys mention that the tops rub the front of their shins when they lean forward. You've seen how much wedge those guys run. It would be an easy fix to trim that down and returf, but it doesn't affect my riding at all.
