- sask, canada
I don't know how Trendsetterz aligns their midshaft to pump, but on my footrocket they use a jig to align the midshaft to the pump. This advice is a quote from my pump shoe thread where I was looking for this exact same info:
"bolt the mid-shaft in and prep pump shoe and surface of hull apply a generous amount glue on pump shoe then install and squeegee pump entrance and wipe off excess glue install pump with drive shaft into mid-shaft with no pump rubber seal ring check pump is square with pump shoe and let dry.Do not screw pump shoe down. Nick Barton Quote "the threaded area of pump and midshaft are jigged and correct" the hull surface may not be."
It was my first time and it seemed daunting at first but it was actually pretty straight forward after I wrapped my head around it, the worst part of it was grinding the 144 shoe out to 148. I have never used 5200 so I don't know the consistency of it, but I used G-flex epoxy thickened to a peanut butter like paste, slathered it all over the prepped area on the hull, put the shoe in place, slid the pump in and bolted it in with no seal and then just made sure that the shoe was perfectly square with the pump once it was aligned perfectly. The thick paste I used filled any kind of void there may have been between the shoe and hull and I ended up with a perfect seal and I have no cavitation.
